DIY..... its cheaper
An oil story
I made a comment that the EXUP above ran for 84k miles without a hiccup on Mobil 1, who knows ? maybe its still going .
I have a strange opinion of oil as a biker, I tend to think a lot of the debate about oil stems from marketing rather than success or failure of the product. Very much like the petrol debate…keep going well, keep going Shell ? yea but doesn’t most of it come from the same refinery ? Isn’t Tesco that some people will not touch actually Esso ? or was it BP ?
Don’t all oils meet a BS approval ? surely the only difference is a mix of detergents and life span ? Given most bikers change their oil every 1k miles , 2k at max it’s hard to see how any oil could deteriorate in that time under normal conditions and still hold a BS approval, even re constituted oils.
What swung it for me back in the mid 90’s was fighting an MGB that that seemed to turn its oil back into crude in 100 miles and emulsify round the filler, when I stripped the engine it was just full of burnt on carbon and sludge and the backs of the valves had huge balls of rock hard carbon on them like half size golf balls !! never seen anything like it before or since.
At the time on TV was an advert for mobil1 , fully synthetic oils were new then in car land and pretty expensive by comparison but the advert showed a bowl of mineral oil being heated over a Bunsen burner and a bowl of synthetic getting the same treatment. One burnt and turned black, the other stayed looking like oil. I was convinced.
Interestingly while changing the oil on the EXUP one day a neighbour wandered over, an old guy who didn’t figure in my thinking as a young bloke then, and started to chat, oh god thinks I, if he says how fast does it go I will deck him !! but surprise surprise he explained how he had worked on the development of mobil1 and had seen the bottle next to my bike. He was fascinated to see it had reached Halfords as when he retired it had been cutting edge (excuse the pun) and way beyond the motorists reach in price. Turns out he had worked for Mobil on the Concorde project where they had found mineral oils just didn’t cut it at extreme temperatures of a RR Olympus cruising at 60,000ft and Mach 2.2 for 3 hours, outside temp at that height could be -60C while skin temp of the aircraft would be about +100c and exhaust temp near white hot…..
I started to think about the temp extremes of the EXUP on a bad day and realised even Mobil1 was probably a little over the top but I was bowled over by the non burning add.
The picture above in the previous post shows the EXUP having its 50k mile service…which was a strip and check, wheel bearings head race bearings etc as a matter of course but worst of all the dreaded valve shim check. I can only say when I stripped the top end the whole engine was shiny new inside. No evidence of burning or sludge or varnishing, the whole engine looked like it had been ultra-sonically cleaned inside.
TBH that’s good enough for me and apart from viscosity variations for different engines I have always used synthetic oils since.
Anyway, just a thought I thought I would share
Done 50K on Fazer 1000's which are just down the road from the Exup development wise.
Absolutely great bikes, forgiving, confidence inspiring, fun, comfy, fast with large fuel tank.
I have ridden the injected successor and didn't buy one.
I used to use an exup in a sidecar most of the guys swore by Mobil 1 and still use it today but oil changed every two meetings.
I had one of the first Fazer 1000s as a company bike. I fitted flat Renthals and toured, did trackdays, including one of the first ever at Rockingham where we used the whole banking. It was a lovely motor for riders with an old-fashioned throttle-hand and the knowledge of how to keep a tight chain through a corner. The heavy crank smoothed like chocolate and gave an impression of endless torque. Mine wasn't an oil burner but I think some exups were, depending on how they were run in. Thrashed, but not from cold, was the recommendation I got and it seemed to work. Sorry for the thread hijack Paddy.
It was a truly great engine, bit bulky in a chair though ? we had a 700 Konig in my youth, it was the talk of the paddock as it had center hub steering :-) thats how long ago it was..
Pile in Martin, its a reminiscing thread :)
Do you mean 500 König?
Looks like a most difficult and impressive feat of engineering; Kim Newcombe was a Top Man.
A 680cc version of the König was prepared... was that yours, Paddy? fascinating article - not sure about running toothed belts round corners like that, though.
This was in a Jacobs "long un" not in a conventional I have heard a lot about the Konig but were they not temperamental?
TBH i don't remember a lot about it now. I remember it eating plugs, i'm not sure about unreliable , more like temperamental, if it started it would probably run the trace but i remember starting it as the problem. Once it went in was great, short chassis, light, very compact lump, flat four , 2 stroke. I only did a few races, My brother in law was the driver and he had a win or die trying approach............which i didn't :)
My Armstrong was the same, we used to warm it up on the last races plugs then fit a new set for the race it was totally transformed when we got a Krober ignition for it the thing pulled like a train after that.
You often see debates about the finish on Calipers and master cylinders. Paint or Anodise ?
I think the answer is both !
I put some parts in the ultra sonic cleaner this morning, all were Black and shinny
Result was some bits stripped back to bare castings and some did not so obviously some were painted and some were anodised. There is no sigh that the bare ones have had the anodising stripped. in fact i am sure they have not.
Does that lay this topic to rest ? I doubt it :lol2:
Dr Paddy,
While your on the subject of brakes, a consultation please. I have the usual brake splitter as in your photo. I also have Marzocchi forks - and a strange looking bracket which doesn't seem to sit the brake splitter in the right place at all. From the parts diagram I don't see a bracket to fit - I think maybe in Cerianis the splitter bolts directly to the yoke? Can you tell me what I'm missing?
Bikes and aircraft seem to go together for a lot of people and i thought you might like to see a few of my pictures. I dont bother much these days as i never seem to have the time.
I have hundreds of these :)
OK hands up who has spotted i am sorting my photos in to some sort of order the last few days.
This is a model i built last year.
This is tamiya's little honda RC166 250cc 6 cylinder. in 1/6 scale. Its about 6" long.
the wheel rims are alloy, the spokes stainless steel, each link in the chain is mabe up of two side plates 2 rollers and pins..
This is a pin and roller
this is a wheel rim, spokes and nipples...and a 2p....and the jig to hold the rim while you lace the wheels.
a half built wheel
and the finished thing
This i a rivet from the seat hump
You get the idea :)
I went to a sunny RIAT once.... although it ws a while ago as it was at Greenham Common ! :lol2:
The Magister was a nice flight - bit like being on an old bike but at 500ft !
I have been breaking an SS this last week or so and i thought this was a good time to warn people with old bevels to check their center stands.
The SS versions are well known to rot but even i was surprised at the state of this late 1982 version.
Both legs have completely rotted through and this bike was very near crashing to the ground as its stand collapsed. None of this damage was visible till i cleaned off some of the chain oil/grease.
Be warned :)
Quick question...anyone ever had damper rods re chromed for Marzocchi shocks ?? Was it hard chrome and re ground or just basic bright polished chrome ?
Be warned :)
Had the same problem with a wee 250 I started rebuilding, ended up jigging the original stand and making a new one.
http://www.ducati-upnorth.com/forum/showthread.php?17576-Ducati-250-street-scrambler/page2
Looking for a part
I need a steering damper bracket for a Darmah with Cerianni yokes. Its a small swivel thing that bolts to the bottom yoke on 1977 on Darmahs ?
any one got anything like that :)
