derek had the bike and changed the front injector and he thought he had found the fault . i took the bike away and he then said to me he did not want to look at the bike again incase it took to long to find the fault. then he changed his mind and said bring the bike into the workshop when i had my 1098 in for belts.he did a compression test on the front cylinder and he then changed his mind again saying take the bike away. thats what happenedDerek and doing the dirty aren't words I've heard in the same sentence before. Derek has always been willing to help the less informed and keen to help others.
A good testWouldn’t it be the case that if you disconnect all the injector connectors and check continuity back to the ecu ?
And if all measure pretty much the same , then the problem isn’t the loom or connector
I can understand his, or any mechanic’s, reticence in chasing an electrical gremlin. It could be a 30 min job it could be a 30 hour job and the customer will have to pay for that time, which, of course, at the larger end they’re not going to be happy about. In my book it doesn’t mean Derek did the ‘dirty’ on you, it appears he just decided it wasn’t a job he wanted to do. It’s a bit strong to bad mouth him for thatderek had the bike and changed the front injector and he thought he had found the fault . i took the bike away and he then said to me he did not want to look at the bike again incase it took to long to find the fault. then he changed his mind and said bring the bike into the workshop when i had my 1098 in for belts.he did a compression test on the front cylinder and he then changed his mind again saying take the bike away. thats what happened
just looked at a video that was sent to me from the guy that was working on the bike. the continuity has been checked by the mechanic on both injectors back to the ecu and they are perfectWouldn’t it be the case that if you disconnect all the injector connectors and check continuity back to the ecu ?
i will try this and even put a plastic bag over the injector to prevent fuel going everywhere. as for your comments about derek, you should not be making excuses for him. if someone did that to you, i,m sure you would be annoyed. he should have said yes or no,not changing his mind twice.Are you 100% certain the issue is the injector doesn’t fire until the bike hits 4000rpm? There’s a simple, but very messy (and don’t be smoking at the time) hack you can do. Pull the injector out of the throttle body but leave it connected into the loom. Start the bike, is fuel squirting out of it? Increase the revs to 4000rpm, does it only start to squirt fuel once it gets to 4000rpm?
given everything you have checked then it maybe the ecujust looked at a video that was sent to me from the guy that was working on the bike. the continuity has been checked by the mechanic on both injectors back to the ecu and they are perfect
just changed the ecu,same problem. i will check the lambada sensor and map one as wellgiven everything you have checked then it maybe the ecu
just a thought does it have 2 lambada sensor’s don’t they control’ low down fueling
I looked at the parts diagram online , I wonder if it’s possible to swop map pipes around on inlet manifoldjust changed the ecu,same problem. i will check the lambada sensor and map one as well
Sorry I'm out on this one.No offence taken. @AirCon is perhaps the best placed to advise but he’s on holiday at present.
I think you’re referring to attenuation which happens over long distances of cables. The injectors just need 9v to open (hence the hack to test them with a 9v battery) so you’d have to add some fairly serious resistance in such a short circuit to get the voltage below that.
It's not that I'm not interested, I just think I don't have anything to addSorry I'm out on this one.
If Nelly's not interested (most unusual) then neither am I.
That makes perfect sense and a better explanation of what happened early on.It's not that I'm not interested, I just think I don't have anything to addThere's a lot of swapping and changing going off which is not proving successful. As I mentioned, the bike needs hooking up to a good diagnostic tool and the live data studying with the motor running. Most of the stuff being tried might have worked on a 916, and has maybe proved a little on this bike, but there's too much going off with the newer stuff. You need to see what the ECU's are seeing and doing in order to diagnose deep rooted issues like these. It's doubtful it's even throwing out any error codes?
Bit of a hike to Glasgow may be an issue......I feel also it was Derek was trying to assist a fellow forum member out but after trying the usual suspects, it became clear, as the thread is showing, that the fault is far more difficult to locate. As Nelly suggests, a possible pop into a shop with the approved Ducati diagnostic equipment seems to be the best way forward
My brothers jag had a similar issue and knew jag labour rates were substantial for any repair but he had a great mechanic who could do the repairs. Aware of the time and stress this was causing before getting it back on the road, he simply bit the bullet and book it in to the local jag dealer for 1 hours fault finding. The fault was diagnosed within ten minutes on their official doo dah and he was able to go back to his own mechanic who was able to order the parts and replace it for him.
In my own long winded way and supporting what a few others have said, it might be time to bite the bullet, get it to an official ducati dealer with official ducati diagnostics to at least find out what the issue is and if you do, decide what you want to do next.
not sure what you mean by that commentBit of a hike to Glasgow may be an issue......
Ducati Glasgownot sure what you mean by that comment
i asked barry hell that question not youDucati Glasgowbit of a hike for you perhaps?
So? I answered it as it was blindingly obvious what he meanti asked barry hell that question not you
wrong. read the way it was worded.may be an issue. i think he knows something that you dontSo? I answered it as it was blindingly obvious what he meant![]()
I don't, but we will seewrong. read the way it was worded.may be an issue. i think he knows something that you dont
it would be good to see the bike being fixed and sold,asapSo Ray, given so many suggestions have been offered, you've run through them and we are still none to wiser, what are your plans now? It would be good to see the bike up and running as the season starts![]()
Just meant it is a bit of a journey to Glasgow with no guarantee of success, I'd be worried they just said leave it with us and they then rack up a big bill following loads of dead ends already looked atnot sure what you mean by that comment
