2011 multistrada 1200s sport injector problem
If there is a reverse of polarity across the injector wiring, then yes, you can damage the ECU. The injector is fed with a permanent 12V supply off the ignition relay, as are the coils, and the ECU triggers them with a signal to earth to close the circuit. Getting the wires the wrong way around would fire 12V into the ECU earth circuit when the ignition relay pulls in. I'm not 100% this is the issue though as you saying it fires above 4000 rpm?
maybe the wiring is damaged somewhere to have caused this but again myself and the mechanic have stripped back all the wiring and inspected all of it for a fault/damage and found nothing.
I was wrong, @Nelly ‘s right 👍 re the injector wiring.
If it were mine, before assuming the ecu has been damaged I would go back to basics. Is there a spark there? Is there fuel there? In post #24 you say it’s the lack of spark that’s the problem and that the injectors are definitely firing.
Swap the spark plugs from front to rear and see if the issue moves with them, if it does then it’s the spark plug that’s at fault.
If the issue doesn’t move, ie stays on the same cylinder, then return the spark plugs to where they were (don’t want too many things moved at the same time) and swap over the HT leads (from the coil to the spark plug) from the front to the rear cylinders. Does the problem move cylinders too? If not, replace the HT leads as they were and swap over the coils.
In this way you’re checking if the problem moves with a component to identify the component at fault.
Alternatively, I would have thought an authorised Ducati service engineer (such as Nelly) would be able to tell exactly where the issue is from the diagnostics.
everthing has been swapped many times from front to rear and the front always fails ,never the rear. the ht leads must be ok because they both work ok on the rear. the diagnostics does not show where the problem is according to ducati glasgow
Both injectors are earthed from the ECU. It's a switched earth to control. They're fed with a permanent 12V from the ignition relay.
This will be solid state switching, with a relatively low "on" duty cycle.
Injectors are NOT designed to be "on" for any continuous period.
just got my multi back from the mechanic. i have an ecu coming soon in the post and the first thing i am going to do is change it just incase the original one has a fault. then try a loom. do i need to disconnect the bikes battery or is it just a case of unplugging the box and then connect the new one.
I’d disconnect the earth terminal off the battery just to be on the safe side but it should be fine to just unplug and plug back in.
I'd definately disconnect the battery before touching the ECU
i am trying to dodge fitting another loom but its getting closer. before i do that i think the only other fault it could be is the electrical connector for the injector on the front cylinder. if i cut off the connector from the used loom i have bought and swap it with the existing one, will i weaken the signal from ecu to injector
No.
I’ve not reread the thread but it’s occurred to me perhaps the injector itself is faulty. Have you tried swapping the injector units from front to rear and seeing if the issue moves with them?
No.
they have been swapped 2 or 3 times and a used one was bought as well. i think my next plan while i have the airbox off again will be to swap them one more time and change the electric connector for the injector.
no offence paul but can i have a second opinion from someone,before i start cutting the electrical connectors of both looms. ie,losing the strength of signal between the injector and the ecu.
I remember, not bike related, watching one of those wheeler dealers and on a range rover.
The injectors appeared to have one or two not dispersing properly. They swapped a good firing injector over to the cable that had the bad firing injector and that started to disperse irregulary too. Turned out the wiring loom itself to those two individual injectors were at fault with a possible break in the wire and the resolution was to replace the smaller loom between the main loom and the injector.
No offence taken. @AirCon is perhaps the best placed to advise but he’s on holiday at present.
I think you’re referring to attenuation which happens over long distances of cables. The injectors just need 9v to open (hence the hack to test them with a 9v battery) so you’d have to add some fairly serious resistance in such a short circuit to get the voltage below that.
its got to be the wiring or connector thats at fault now. if the rear was at fault the bike would be f---ed, and not run at all. just had it out again to double check with the dtc switched off and the power delivery is great after 4000 rpm.
he did the dirty on me and backheeled it after saying he would look at it. all he did was change the front injector and check the pressure of the front cylinder,cranking it with the relay disconnected.
I'd have thought he'd of been able to sort it for you, loom the last thing then 🤔 bad earth could cause the issue but on the loom good luck with finding it 😬
