You wouldn't get me to the top of that even if it had a lift
The actual living pod is only 60 feet above the ground. However, if the chimney is of similar dimensions to the one Fred is pictured sitting on I can't see how there'd be much room within the shaft for anything but a very compact lift. Certainly no stairs. The estate agent is saying there's scope for all sorts of further living spaces, which would presumably mean adding more pods lower down as I'm guessing they've calculated that 60 feet above the ground is the maximum height for external add-ons. So you're buying a five story house (unbuilt..) with a redundant 180 chimney above it that will require constant maintenance.You wouldn't get me to the top of that even if it had a lift![]()
It mentions a roof top garden, feck thatThe actual living pod is only 60 feet above the ground. However, if the chimney is of similar dimensions to the one Fred is pictured sitting on I can't see how there'd be much room within the shaft for anything but a very compact lift. Certainly no stairs. The estate agent is saying there's scope for all sorts of further living spaces, which would presumably mean adding more pods lower down as I'm guessing they've calculated that 60 feet above the ground is the maximum height for external add-ons. So you're buying a five story house (unbuilt..) with a redundant 180 chimney above it that will require constant maintenance.
The proposed pod is three to four bedroom and I bet it would cost more to construct than a similar sized building on the ground, plus the top of the stack requires extensive repairs which will be expenisve.
Really you're paying 300K for a vertical building plot on which you have to build living accommodation from scratch. You're not buying a convertable building. By the time it's all completed I bet you'd be well past the £1.5million mark.
I also wonder how they've calculated the structural loading and integrity of the stack once you start adding pods, weight and wind deflecting surfaces higher up for which it wasn't designed. It's only an 18" thick brick tube held together with lime mortar.
The height wouldn't bother me if I knew it was structurally sound, but it's going to need a huge amount of services back-up. What if there's a power cut and you can't use the lift? You'd need an extensive service building on the ground with a generator, water pump etc.
It will be wildly expensive to build. Truly a modern folly. It's a cool idea but not for me. It's not worth 300K IMO. 100 tops. It will be bought by a self builder with more money than sense or a developer who'll make a packet flogging it on.
It's on the roof of the living pod, not on top of the chimney. Fookin draughty...It mentions a roof top garden, feck that![]()
PhewIt's on the roof of the living pod, not on top of the chimney. Fookin draughty...![]()
In 1976 I walked the length of the beach with the girl who became my wife. We ended up as red as lobsters and had to find a chemist for calamine.Has anyone ever been to Torcross in Devon?
Check out this 2 bedroom cottage for sale on Rightmove
2 bedroom cottage for sale in Port Cottage, Torcross, Devon, TQ7 for £675,000. Marketed by The Coastal House, Dartmouthwww.rightmove.co.uk
Surly that house will be under water by nowIn 1976 I walked the length of the beach with the girl who became my wife. We ended up as red as lobsters and had to find a chemist for calamine.
Your autocorrect changed condoms to calamineIn 1976 I walked the length of the beach with the girl who became my wife. We ended up as red as lobsters and had to find a chemist for calamine.
I is SvelteYou're right there fatty. You'd be wedged tight about 10ft up.![]()
Farm with two-mile race track is up for sale in Wales
This farm-based race track in Wales is over two miles long and up for sale for an eye-catching sum of money.www.visordown.com
Here's the listing.
Certainly bigger than the "24 Le York kitchen" race. Couldn't buy a place in Wales though. I'd run out of spit before finishing the name
This is surly you when you're posting...Certainly bigger than the "24 Le York kitchen" race. Couldn't buy a place in Wales though. I'd run out of spit before finishing the name
Yep, Mongy Monkey is deffo youThat might be me after seeing yet another picture of your push me pull you bike just before I boke![]()
your gifs/videos are very worrying!
That is a little more Noobiesq - nice but too brightCheck out the sofa...Exi has the same taste seemingly as what must have been a Victorian brothel owner.
This place was SSTC at one point, then back on the market for a bit, and has just dropped £300k
Check out this 9 bedroom manor house for sale on Rightmove
9 bedroom manor house for sale in Summerlands Hall, Endmoor, Kendal, Cumbria, LA8 0ED, LA8 for £2,650,000. Marketed by Hackney and Leigh, Kirkby Lonsdalewww.rightmove.co.uk
Anyone who calls themselves an entrepreneur is a grade A wankerSavills Property Auctions | UK & London | Upcoming
View the listings catalogue, register to bid and find out where and when our next auctions are with our online auction calendar.auctions.savills.co.uk
Millionaire debt collection boss from BBC 'Bailiffs' selling Thames private island
A private island on the Thames owned by millionaire entrepreneur and former BBC Bailiffs star Jamie Waller is up for sale. Hallsmead Ait, a 4.75-acre wooded island near Shiplake Lock in Berkshire, is listed by Savills and will go to auction next month if unsold. Waller, who bought it for around £500,000 three years ago, hopes it will become “something meaningful,” such as an entrepreneur retreat. The island features a landing pontoon and scenic river views.
Says the Staircase EntrepreneurAnyone who calls themselves an entrepreneur is a grade A wanker
Chippy.. im a Chippy and proud of itSays the Staircase Entrepreneur![]()
