I was looking to put sensors inside the tank, to measure water temperature.You have to remove the foam to get the sensor to touch the metal of the tank.
A simple thermistor would do ptc or ntc..
If you get the sensor on the tank skin and insulate over you effectively get thatI was looking to put sensors inside the tank, to measure water temperature.
We've circulating hot water.... the losses through the associated pipe work are enough to keep the boiler on about 10% modulation.Thermal losses from the domestic hot water system are a bit of a surprise!.
We had a new hot water tank installed a few years ago when the boiler was replaced, went for a solar tank so two heating coils installed (one from the boiler, one for solar) as the incremental cost was minimal. Had the solar bit fitted 18 months ago so the tank is now peppered with control thermocouples, with outputs displayed on the control panel.
Overnight heat loss from the tank was far in excess of the 1.49 kW/24h quoted by the manufacturer, and conclude that this loss was from heat conduction along the copper pipes to and from the tank, which although well lagged around the cylinder, just radiate the conducted heat under the floorboards where the pipes aren't lagged.
Not a big problem when the house needs heating, but just highlights the thermal losses and associated cost with current energy pricing if you use the boiler/immersion heater to heat domestic water during periods when your heating is off, you're heating a house that doesn't need it and may actually have benefit from cooling!
Have you considered Fischer Future Heat?We've circulating hot water.... the losses through the associated pipe work are enough to keep the boiler on about 10% modulation.
So in the summer that is off.... trying to use routines in alexa with smart switches to keep a happy compromise. I've purchased a new pump with 264 on/offs per 24 hours... but the fittings are different so it's still in he box... for now.
Yes... pure snake oil... 'The fool doth think he is wise, but the wise man knows himself to be a fool.'Have you considered Fischer Future Heat?
