The thing is to set it and have the faith to just leave it. For the first couple of days at 19c it felt chilly, there’s a massive temptation to turn the thermostat up a few degrees, but after a couple of days it settled down and was fine thereafter.
Just a few degrees on the thermostat makes a huge difference at the boiler. All houses will be different but if ours is set at 19c the boiler just comes on and off for about 10-15 mins maybe half a dozen times a day. At 20c it will be on for about 20-30 mins each time, at 21 it will run for 20-30 mins every 2 hours, get up to 25c and it’s running continually.
Most people come home to a cold or warming up house, find it chilly inside once they taken off coats etc and then wack the thermostat up. The house has just heated up by the time they ho to bed when the heating goes off and the house temp falls and the cycle repeats.
Have faith in modulation
But yes gadgets are cool
- speaking of which I guess Apple must have some home heating controls, I must check (cue
@Loz from stage left
