Netherlands Visit last week...
She's home!
Thanks to Jan Willem and his Mum Jo who had me over to stay for a few days in Dordrecht, I have recovered my fully rebuilt motor from Jan Biggelaar.
I had more than a few beers including a Dutch brew at 9% by volume (FX: Yum!), loads of Dutch delicacies and some frustrating times with trying to get some work done using Windows 8, which seems to be considerably less reliable than a 1970's bevel drive Ducati in a thunderstorm. No news there then.
I can't fit it into the frame just yet as I haven't had the supports made up for the Metmachex swinging arm. Time for a visit to Russell....
I know I have posted pickies of the engine before, but they were by Biggelaar in the Netherlands and it is sooo hard to resist. For the Eagle eyed, the clutch cover is a polished pattern part and spot the blasted & stoved filter cover. Anyway, here she is on my rather untidy bench:-
I had the chance for a chat with Jan & he has taken a stab at re-jetting the carbs to match the 88mm High compression pistons; Bearing in mind his experience I am hoping he isn't too far out. He has slightly altered the jets feeding the heads to increase the oil flow to the heads as it's a springer engine there's a bit more work going on up top.
Yes, that does mean a bit less less is going to the bottom end but it does have a 40% greater capacity oil pump, the con rods from Godden's 1,000cc speedway engine, full flow oil filtering and Lacey's original spec silver coated big end bearings to help it cope with its extra 39cc capacity and high compression 905cc wholesomeness.
Let's not forget the lightweight straight cut clutch basket, 3Kg lighter...
Which is part of my plan to really spank the SS
