winter project
aircooled
My 1992 750ss is in need of a overhaul so engine is coming out casing of for coating down pipes for chroming engine wise it will get what ever it needs, this is the first time i have attempted anything like this and am already scratching my head on the best way of geting engine out of the frame, i have come up with a number of ideas, but if anyone has already removed a engine from a 600/750/900 it would be great to here how you did it
Frankie
Frankie
Frankie, it's a doddle! All you need to do is undo all the connections, i.e. wiring etc. whip off the exhaust/carbs/airbox. Disconnect the rear shock from the frame, support the engine on axle stands through the rear/lower engine mount, use a trolly jack to hold the engine up at the front, and literally lift the frame complete with front end off the bike. See image of mine a couple of weeks ago..... hope this helps. :)
Frankie,
He is right about it being a doddle. :)
Ed,
For such a "new" bike why have you taken it down to so many bits?
Hi Derek,
I have had (or what turned out to be) the oil feed o-ring weeping since I re-built the engine. It annoyed me after every ride having a small patch of oil at the back of the cylinder. (& just my luck, on the vertical cylinder). I actually rebuilt it back in 2003 when I first started the Project, but was made redundant just after completing it so it sat under my office desk for a year waiting for the chassis!
Even though it's only done a low amount of miles, I wanted to give it a right going over with the old cleaning cloth! :)
It's now adorning the lounge floor (images elsewhere on the forum) :)
Ah! I understand what a scunner that is. Everything has to come to bits to get at one wee o-ring. A lot of work for a very easy fix. I hope it's OK this time.
what great advice, engine is out, and done without an assistant had a couple of momment as garage floor is not level, and snaped one of the engine mounting bolts, thanks for great advice iam sure i will be back with lots more questions.
Frankie
Derek, just as a precaution, I put a very small amount of 3Bond round the new o-rings. I've never done it before (never had to) but I really don't want to have to take it apart again - although it was and is a labour of love!! :)
Frankie, good on yer. isn't it so much easier to work on without the frame in the way! :)
:eek: :eek: :eek: :eek: :eek:
You forgot to mention the Yellow Pages!!!! :rolleyes:
yer I was waiting for your comments Mr Ravie!!!
...and it was two copies if I remember rightly!! :D
I usually try to keep sealants well away from any oilways but I can understand your reasons with that one.
Derek, I do too, but I was very careful and only put a tiny bead round the outside edge of the o-rings
Hi Derek,
I did front cylinder o-ring on GT this summer. 100 miles later the back one has gone.:mad: The valve stem seals have also dried out with sitting so it's an engine out job and do it properly now. It's annoying as it's not using much oil but I know it's doing it!! I don't want old British bike owners taking the pi$$ just cos their bikes leak oil like a seive!
engine in the process of de-gunking am then going to pull casing of ready for re coating want to get these back to original, looks like a satin black finish, but it also looks like they have been badly re-painted at sometime, so not 100% shure also dont no best method for coating should i paint, powder coat any ideas would be much appreciated
frankie
frankie
Eonan has just done all this to his M900 engine. I'm sure he'll be along with plenty of advice.
looks like i have found the company i need, they are called triple s powder coaters in Bradford they do frames, wheels, engine cases and crank cases anybody know anything about themhttp://www.triple-s.co.uk/
also worth a look at is the Stephen Smethust web sitehttp://www.aloh.co.uk/Pages/sample.htm
Frankie
Up date on winter project. Heads, barrels and pistons all removed with the help of large amounts of penetrating oil every thing looks fine so far. i am making a start on striping the heads to day. The haynes manual says i need a special tool to remove closing rocker arm and spring is this correct or can it be done with out the special tool. All advice and tips on striping checking and re-building the heads would be greatly appreciated
frankie
frankie
Frankie, you don't need the special tool. collets etc. You can screw a spare bolt into the end of the rocker pin and pull it out, taking care to note where the shims are located either side of the rocker arm. Hope this helps :)
aircooled said:
Cheers Ed
I am having trouble un-doing the cam pulley bolt at the moment any tips
thanks frankie
...if you are referring to the castle nut - then you will need to hold the pully still (normally with two pinned special tool) and the castle nuts are generally single use only - they are so cheap I would always replace them. If you have to destroy it then don't worry too much, it's just holding the pully still without damaging it.
oh,
sorry about that. Do you have a dealer close to you whereby you could take the heads in and borrow their tool. you could try putting the barrels & heads back on, put the belts back on (you gonna replace them anyway) - tension them and use the engine as a steady for the cam pullys. Then carefully using a drift crack them off. Bit Heath Robinson but it should work.
If you've already take the opener rockers out you could put a metal bar through the top of the cam box to stop the cam from turning so that you can unscrew the castle nuts. Getting them off is another matter.
As Ed says you could try a drift. It might also be worth a look in your local bicycle repair shop. Quite few push bike bits use these castle nuts and there might be a tool there that will fit. I managed to get one to fit my the clutch nut on my son's Honda NS125 a couple of years ago at a bicycle shop.
If all else fails take the heads to a dealer and get them to undo the nuts for you.
You will also have to consider what you are going to do about fitting new ones when you put it back together.
:) oh happy days took heads to a local engineers, take one air gun and 30 secs later they were both off. just taken him a bottle of wiskey as a thank you and warned him i may well be back, top guy. Could i put a standard stainless nut as a replacement cannot see why not. many thanks for all your help so far, its a big help to have people to talk to. please dont go away as i am sure i will be stuck again very soon.
I thought about that but then used new ones - they won't come undone, there is always the risk that normal nuts could (with disasterous results). Derek correct me if I'm wrong, but I believe its also a fine thread - it's been a while since mine were off! :)
Yes, it's a fine thread - 15mm x 1mm pitch.
I think the castle nuts are relatively shallow but if there is enough thread you'd want a self-locking nut of the all metal variety like Aerotite or similar. I don't know if you'd get them in these thread sizes though.
Normal nuts with red loctite might be an option although they could be difficult to get off the next time, though I guess you're hoping there won't be a next time.
I did a bit of web searching and M15 x 1 nuts just do not exist. So it looks like the OEM jobs or nothing.
...they're not that expensive are they Derek and lets face it, they are the correct thing to use. One could always fashion one's self a tool for the job! :)
It's not the nuts that are expensive at £3.29 each its the tool to take them off and on that is at a whopping £91.91 :eek: and I think that's less VAT!
