Will changing front sprocket bugger speedo
Banditnomore
Hi All and a merry Christmas and NewYear to you all.
Just a quick question I've been pondering for the next batch of prezzies now the Christmas ones for teh bike are accounted for.
I want to drop a tooth of teh front sprocket of my 2003 800SS to make town riding a little easier. But will this screw up the speedo??
Any comments gratefully recieved.
Chris
the speedo works off rear wheel rotation so is related to tyre diameter not revs. by changing a front or rear sprocket size its just like hanging gear at a fixed speed, the revs alter but your speedo reads the same speed so no it won't screw up your speedo reading :)
Ta
Thanks for the reply. Its only my third bike. The gsxf worked of front wheel the bandit off the gearbox and noe apparently the Ducati works off the rear wheel. I didnt know there was so many methods out there to measure a bikes speed. Apart from the laser method the police also used for me as well.
Ta
Chris
Ta
Chris
yea & aparantly theyre laser guns are not meant to be used on bikes.
causing quite a stink atm.
/ian
It will be good if they get stopped from using them as I think its been taken so far as to be an abuse of power. Although i do worry where they will get the money from if they have to pay all the fines back, speaking as someone reliant on the public sector for work.
