weeveetwin
Just been reading this. K&N filters tested against the rest.
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
The issue Paddy mentions wont affect your carb bikes as they dont have a MAFThat's a worry; I bought two sets of K&N's as a result of considering bore wear, a set for the SS and a set for the GTS.
Bearing in mind the GTS is now 904cc with high compression pistons, the last thing I wanted to do was restrict airflow though the already restrictive 32mm carbs. Drat.
Not on most bikes you don't and certainly not on Ducatis. The airflow isn't measured at all. The injection and ignition maps are preset in the EPROM or memory of the ECU, providing a pre-determined amount of fuel and igntion advance for the values of throttle opening and rpm. These are modified by air temp, engine temp and air pressure to suit. Read all about how it works hereOne of the problems is with fuel injection, you have a MAF sensor after the filter which measures airflow and give totally wrong readings after its coated in a fine film of K&N filter oil.
Sorry Paddy, I thought this was a Ducati forumYea I know but i was talking in reference to my mention of tuning the Audi in my previous post.
Sorry Paddy, I thought this was a Ducati forum![]()
