bigtwin said:
'04 999, reg April 2005
I've had the battery on an Oximiser over the winter. Status has been sitting pretty on 'Green' but would she start today? Would she b*ggery! :rant:
Called Ducati Assist, AA arrived, got it started
)), ran it for 5 minutes and tried to restart it. Dead as Ducati with a alarm fitted!!
It will be recovered to Ducati Coventry on Monday.
Why, as they say, o'why o'why!
The batteries in the 999 (and all of our other machines) are japanese items and are of the same quality as those found on most other manufacturers bikes.
We get a few of these calls at this time of year after the bikes are coming out of hibernation. Try not to get too upset, here's what to try:-
There could be a simple answer here mate! Make sure that the leads on the Optimate are correctly fitted on.
The status could show on green but the connections may not be on right! I bet if you connect it up again the led will show orange, you'll know they weren't on right in the first place. (an easy mistake to make, done it myself)
Double check it and leave overnight and try tomorrow late afternoon, it should be a lot better, but don't try it over and over again on the starter, you'll just drain the battery again.
If she doesn't fire, check the optimatre leads are ok again and leave it till Monday Morning, check if she'll start before calling out the AA.
Really leaving it for 48 hours on charge is preferrable. That way you will get a "deep" charge.
It could very well be the alarm, but I doubt it! It sounds like a deeply disharged battery that needs a long charge.
With any luck, the battery will come back up and be fine for the duration. However you'll know by Monday morning if you need to take it down to Coventry to get it sorted.
PM me if you need any advice, i'll be working late for a bit tonight and i'll be in at some point tomorrow afternoon for a while and i'll check my messages then.
Main thing is, don't worry, whatever happens it's something really silly that's easily fixed.
Enjoy your weekend
Mart
