All of emHow many fingers you got chiz![]()
The 3 together is 2The two together is three
All of em
And there isn't a way to tell other than keep replacing everything hoping i replace the part thats broken?There seems to be one of three problems
The axle's fucked
The swing arms fucked
Or both.
Interesting, in using lm48 assembly paste which is industry standard.I doubt the swinging arm is at fault. It'll be an issue with the hub/axle/sprocket carrier.
Unless the threads are visibly damaged (check the nuts as well as the studs/axle) Hugo could be on the money with excess grease preventing full metal-to-metal contact. Bike gets ridden, hub gets warm, grease melts away and leaves a slack thread. I've heard of that happening in other situations, not necessarily on bikes, if the wrong grease is used. Most engineering greases are sheer thinning, which means that under sheer stress (compression) they revert to liquid form so metal-to-metal contact is assured. Some greases like vaseline are not sheer thinning and would create this problem.
Worth disassembling, cleaning off all traces of grease, torquing up dry and riding it to see if it does it again. If it doesn't, that's your answer you're probably using wrong sort for grease.
When a bolt is lubricated - less torque is required to achieve bolt axial load or tension. Reduction of torques for lubricated vs. dry bolts are indicated in the table below.Also, dry torque will be significantly lower than with assembly paste, so 156nm might end up like 90nm
Yep, that's what I meant to say—you phrased it way better!When a bolt is lubricated - less torque is required to achieve bolt axial load or tension. Reduction of torques for lubricated vs. dry bolts are indicated in the table below.
Lubricated Bolts - Reduced Torque
[th]
Lubricant
[/th][th]
Torque Reduction
[/th]
[td width="232px"]
Graphite
[/td][td width="232px"]
50 - 55
[/td]
[td]
White Grease
[/td][td]
35 - 45
[/td]
[td]
SAE 30 oil
[/td][td]
35 - 45
[/td]
[td]
SAE 40 oil
[/td][td]
30 - 40
[/td]
[td]
No lube
[/td][td]
0
[/td]
Example - Reduction of Torque when Bolt is Lubricated
The maximum tightening torque for a slightly lubricated 1" Grade 5 coarse bolt is 483 lbf ft. Dry bolt torque is approximately 30% higher - or 628 lbf ft.
Tdry = (483 lbf ft) (1 + (30%) / (100%))= 628 lbf ftIf the bolt is lubricated with SAE 30 oil - the torque compared to a dry bolt is reduced with approximately 40%.
TSAE30 = (628 lbf ft) (1 - (40%) / (100%))= 377 lbf ftNote that if torque specified for a dry or slightly oiled bolt torque is applied to a lubricated bolt - the bolt may overload and break.
I have a £20 note and a £50 note.The 3 together is 2![]()
£20 + £50 + £70 pleaseI have a £20 note and a £50 note.
You can choose to receive £20 or £50 or £70.
How many choices do you have.
I choose violence. And a cool seventy quid minimum plus maybe a watch, too.I have a £20 note and a £50 note.
None of those are problems.. whats ya point?I have a £20 note and a £50 note.
The problem is I don’t have the £20 or £50 notes, have got 36p in coins though.None of those are problems.. whats ya point?
I am very familiar with this problemThe problem is I don’t have the £20 or £50 notes, have got 36p in coins though.
Are you even a real chippy ?All of em
On one hand?He has 7
Most of em have been Stiched up or back on at some point, qualified enough?Are you even a real chippy ?
FootOn one hand?
Maybe im polish, they have the same word for fingers and toes...Foot![]()
So do the Czech's - hand fingers and foot fingers.....Maybe im polish, they have the same word for fingers and toes...
