It’s only water over the winter months, no salt needs be used around here.The factory won't grease anything as they are sealed for life bearings, the front wheel spacer in my ST4 was dry when the bearings started to rumble but no corrosion and no external dust seals - must be that lovely West Cork weather you keep banging on about![]()
@BobTheBounder has a point though so I’ll probably alert the dealer/Ducati. The front axle, as can be seen when zoomed in, has a ribbed finish and appears to have a lacquer or anodising on it. The corrosion has got under that and, thanks to the ribbed textural finish can’t easily be rubbed away with emery cloth or ally oxide paper etc
