All oils - mineral, semi-synthetic, fully synthetic should be mixable, except for vegetable oils - Castrol R.Any problems with compatability with the straight 40/50?
Rock Oil do a special mix for needle roller/roller bearing engines. The problem is that multigrades do not maintain oil pressure through roller bearings (the tolerances are to big basically)
Rock Oil 'TRM' (Twin Cyliner Racing Mix)is specially fomulated for use in roller/needle bearing engines and is used in classic racing withouty the problems of straight 40's or 50's. (extended warming up times)
Try your local Rock stockist (you'll probably have to order it) or send an email through the website www.rockoil..com
Go to the motorcycle link and check out the details for TRM in the pdf. online catalogue
Hope this helps
Obviously so Gordon. I didn't mean that you could freely mix them but it should be OK to top up with if you are desperate and there is no need to strip/flush the engine when changing from one type/brand to another. Just a little common sense is all that's needed.
p.s. Are you in the habit of disagreeing with me![]()
only when i disagree, not at other times![]()
Using Morris V Twin at the moment, not quite done 1K and still quakin' in my boots ;-)Morris oils explained straight oil versus multigrade in much the same way as Andrew. I have put Morris' s straight 40 in my ss, coming up to 33k, not been apart yet.
Quakin' in me boots, Kate, X
