Welding for beginners
West Cork Paul
Man in a Shed
As some of you may know I’ve got this old aka scrapped Transalp that’s come into my shed to save. There’s a thread about it elsewhere in this section of the Forum. There’s an exhaust stud that’s seized in there (and was cut off by the PO in order to get the exhaust off). As per @WAYNE ’s suggestion I bought a stud extractor
but sadly there’s not enough stud left for it to be able to grip hold off. So, plan B is to weld a nut onto it and use that to try and get it out.
There are just two problems.
1. I don’t have a welding machine (although I do have an auto-dimming welding helmet 🤣), and,
2. I’ve never welded (apart from plastic welding).
Now I could get a mobile welder to come around and weld the nut in place but I suspect that might cost me almost as much, for a 2min job, as buying a welding machine might.
So, I’m asking the Hive, what sort of welding machine should I buy to start with?
There are various stud extractors for the job, If you want an easy welder use a MIG, easy to use and very handy to have.
I have said it before studs are my fucking nemisis, hate the fucking thing's!!
Get a MIG welder assuming you’re only looking to weld steel , doesn’t have to be big or expensive . A large gas bottle and decent regulator works out much more economical than the disposable bottles .
edited to add don’t bother with a gasless setup …
Gas less is ok'ish inside
Buck me 😮, I started watching that and I’m thinking, I just need one small dab of weld, I’m gonna put the whole thing on the long finger and GAMI 👍
I would go for looking at stud extractors, i have a mig welder and i haven't used it for 7 years, i know that because that was the year the drunk Guinness hit me head on.
I used it on my C90 Cub in 2016 to weld up some of the frame to get it through the MOT that year, it is handy to know it's there if needed.
I have a stud extractor that looks like a drill chuck. If that first picture is your stud there is more than enough for it to grip.
I've also been watching combat dealers the 2 blokes who do his restorations are always removing broken studs from 80 year old tanks.
They heat the stud with an induction coil then immediately drown it in cold water.
That’s my fear, it would get used for this then never again so I’m probably better off going down the GAMI route.
I know the sort. At this stage I’m loath to use one. The style I have is supposed to grip the stud without damaging the thread. That’s bollx. The chick type ones will do just as much damage if not more. Readers may think ‘So what? It’s knackered anyway and destined for the bin, who cares if you damage the thread?’ Well, if I damage the thread, as has happened already in my attempts and I’ve had to re thread it, then I can’t get a nut onto it and I’m left with no option other than to drill it out and re thread the hole, and that relies upon me being able to drill straight down the middle of the stud and its threaded hole without being able to rig up any sort of jig without taking the engine out and I really don’t want to have to take the engine out as I know a whole load of other bolts are going to be seized. To avoid that scenario I’d rather see if it is at all possible, with heat, to get the stud out but I need to be able to get some purchase on it to twist it.
How to weld one nut onto one broken stud if I had no welding gear…And no experience welding…?
I would either ask a local blacksmith type to come out and do it for the price of fuel and a drink.
or I would buy the cheapest, nastiest any make any power working used stick welder via ebay or wherever, get a couple of decent quality rods for mild, clean everything up and just touch weld dead in the centre of the nut until it and the stud are glowing orange. That will weld the nut on, but also break the scale or loctite holding the stud in.
It should be quite difficult to get this wrong as, if the weld lets go and the nut spins off, you can just do it again and every time you do it the stud gets longer, and the hold of the stud in the head gets weaker.
Then I would use the rest of the rods up on scrap metal and see if welding interested me.
If it did I would get a half decent mig (i.e. £3 or 4 hundred, not £1 or 2 hundred and start with that.
Agricultural welding Think rust, shit paint etc then use sticky rod. Clean well prepared metal then mig.
Mig is easy if you've already got the hang of stick welding.
I have something like this:
It will weld anything from RSJ's to tin cans
The small inverter stick welders are highly underrated and easy to use, so would be a good place to start.
I'd go for TIG. The reason for this is with MIG although you can vary the current & the feed speed for the wire you have to get them right & once you pull the trigger you are stuck with that setting. Yes you can adjust them, but with TIG you hold the torch while the molten pool developes & you choose when to insert the filler rod.
To me, personnally, that just seems a better way to do things.
Takes a lot more practice though, but if you have the time well worth it
Other than 'hobby' tacking things together welding is something that is quite skilled, Aluminium welding even more so, unless you invest quite a bit of time into practice (and assessment of the results) you will probably end up with multiple MOT disappointments.
If you're serious an evening course at a local college would be worth exploring. I spent a year at Technical College in the 80's which had a welding element once a week and couldn't replicate anything near as successful as blu-tac :oops: Machining was no problem but welding was 'different' :ROFLMAO:
Exactly why I didn’t attempt to learn for my little project, I mean: I couldn’t afford the 10 years it would take to master it so I went to welding Guru Chad off of Hull 🤷‍♂️
I did a 2 year welding course at college back in the day, i was good at arc and gas welding but mig is on another level.
I didn't do good at mig, no fucking patience me!!
