Water in my oil
mikeystill87
hi everyone,
I have just replaced the oil pressure switch on my supersport, when I took the old one off there was water inside it. Have also noticed a bit of white sludge under the oil filler cap and my site glass has gone all misty/white which i doesnt go away at any point. Not too sure what to do about this? Dont think much water could of got inside through the switch but it will definitely need an oil change. Maybe an engine flush? has anyone had any problems like this? Only I could get water in an air cooler engine!!
Ducati are well known for this, a long run normal cures it. It's condensation due to the cold weather. After a good run leave the oil filler cap of to let it evaporate not forgetting to put it back before the next ride.
It's normal with these engines at this time of year Michael. It is condensation from combustion gases due to the engine not getting hot enough to evaporate them off, especially if you do a lot of short runs. Best thing is a good long run. Leaving the oil filler cap off overnight after using the bike helps too.
I agree with aboveleave the filler off after a good run. It is a problem I have had on my bandit last year and got really frustrated with it, changing oil a couple of times. I travel only a few miles to work so engine was not really getting up to temp before I swithed it off! It is surprising how little moisture it takes to create the milky oilyness though, it looks worse than it is.
Agree with the long runs also make sure you have the right grade of good quality oil , will help to get it up to temperature.
Cheers guys, i'l give that a try. Bit of relief too that there's nothing wrong with it. Hopefully temperatures rise soon, itching to give it a good long run.
Had the same problem with my wee monster and 750ss,the long runs on the bikes does help,although i still take the filler cap off to get rid of what moisture still collcts there.
This is common on all engines, water or air or air/oil cooled.
When I worked as a mechanic the number of panicked people thinking they'd blown a head in autumn winter time was crazy.
Short runs and not getting the engine up to a high enough temp like you would on a good long run creates condensation in the crankcases, this leaves the milky whie sludge under your filler cap you're seeing there.
The trick is a good long run and work the engine, get it properly warmed through and you'll see it dissapear.
