Hi Easy Rider
Your not going to like this answer but here goes, To machine your discs you would need to grind them on a properly made fixture, as most people replace the units most engineering shops would not have this item. To ask a tooling company to do this for you would more than likely cost at least half the cost of replacement therefore your back to the area of better replaced. It unfortunately, as I'm sure you have checked, is not a cheap option.
It's also worth checking the wear spec on the discs, this may be 0.5mm which is near 0.020", now to start to feel anything on your brakes, brake judder, you normally find the warp is around 0.005", to machine this out you take 0.006" - 0.007" off each side of the disc. this would equate to 0.014" max. which then puts you near max wear of the disc, back to square one. Better to replace.
Sorry there is no good news. :sorry:
With a car its easier, tooling is easy, you can turn them down on a lathe and wear is large.
Just one thing though, check out this thread before you do anything, It is possible you may solve your problem with it
http://www.ducati-upnorth.com/forum/showthread.php?4721-quot-Warped-quot-Discs
Hope this assists in your decision making.
Stay Safe!
