Hi,
My monster is an M1000ie (2004) and I sent a sample of flaking paint to RS motorbike paints. It's a reasonable match - I would say a little brighter but looks good. The key to any good paint job is preparation. In my case it was the underside of the crankcases and behind the starter motor. If you have the engine out then all the better. Once all the loose flaking paint was removed I then used a dremel plus assortment of wire brush bits. This is the boring bit, basically I cleaned it until you get a shiny finish i.e no oxidised areas visible. You then use a tack cloth and wipe solution to make sure all is clean and devoid of bits. I then sprayed on several light coats of two pack primer which is an acid etch to ensure good bonding of the paint. The paint available from RS motorbike paints is classed as light grey for Ducati's. Several coats of this and it looked great. I finished it all off with several coats of two pack lacquer with hardener again available from RS motorbike paints.
I have my own compressor and artist air brush with a selection of nozzle sizes NOTE: Some artist brushes are only suited to water based paints and can't handle large pigment sizes. They sell rattle cans but I prefer selective spraying with minimal masking which is difficult to achieve with rattle cans. However then you need to purchase a compressor etc which negates cost.
The primer, paint and satin finish lacquer is good for 200 centigrade which is fine for crankcases but not the barrel/head.
I've used my monster every day come rain/hail or snow over the last 2.5 years commuting etc and its now in it's third winter and on the areas I've painted it's still fine. However other areas are starting to flake. In fact I worked on her at the weekend fixing the other annoying areas and now it looks brand new. Hopefully it will last a while.
Geoff
