If this is a "one-off" then I would kind of do what Pict suggests.
Firstly don't do this on your own if you have not had much experience of transporting. You can easily get that "Oh sh!t" moment if bike is stuck at top of the ramp and you can't move forward or back.
If using axle stands the stands would be best secured on their own and seems like too much hassle for one trip.
Have you a ramp to get bike in and out? If you don't have one a scaffold plank will do. Best take the fairings off as there is a chance you will foul the belly pan as it goes in/out. The fancy ramps are convex at the top to stop this.
Put the front wheel of the bike in hard against the bulkhead in one of the front corners.
Put a cable tie on the front brake and put it in gear.
I wouldn't recommend ropes but use proper ratchet straps or the self locking straps. (can't remember what you call them but I have half a dozen at least).
I would disagree about not using the side stand. I would (for one journey anyway) and I would secure with a strap off the front at each side maybe off the yoke. Strap on right can take more of the strain so there is not too much pressure on the sidestand. Stick an old rag in between the strap and the securing point to stop any rubbing.
Unless you have a wheel clamp fitted by not using the sidestand there is a danger the bike will simply slide through 90 degrees and end on it's side by using just the straps. ( want to know how I know?
I would then run 2 straps back to the rear of the van at each side and that will guarantee bike is secure.
Don't compress the forks too much if you can avoid it (against the bulkhead should avoid any need to anyway) as this is bad for the seals to be continually compressed.
Other thing is stop after 5/10 minutes and check nothing has slackened off, re-tighten if required.
If you were at the other end of the country I would do it for you.
