Valve Cover Refurbishment
Richie53
Well-known member
Having removed the horizontal cylinder valve cover, I found out that the gasket had been glued onto the cover and will have to be replaced. It's also apparent that the front cover paint is blistering through some localised corrosion and is looking rather tatty. What's best for refurbishing them;
1. Paint stripper followed by a removal of corrosion by wire brush, etch primer and appropriate silver paint or
2. Vapour or soda blasting followed by etch primer and appropriate silver paint?
Number 2 but i am sure someone else will be along soon with there opinion(y).
If'n you don't mind employing plenty of elbow grease prepping the covers then numero uno
If'n ye canna be ersed with the prep, then pay for the prep and coating by choosing numero due 👀 (y) :cool:
Did you have any corrosion? If so, how did you remove it? Did it leave any marks or pitting on the clean metal?
No I didn’t have any pitting just flaky paint
I did look at getting it blasted and painted etc but would of been cheaper to buy a new cover
it was about £100 ish
It's just the typical aluminium oxide corrosion I have and if I recall correctly, it's only on the surface - unlike rust so it shouldn't really leave any pitting.
Yes, if not advanced then aluminium tends to form a surface oxide coating so rubbing off should be all you need, then proper clean and coat will be good
