valve clearance, correct measurments....
dunlop0_1
Just checked:confused: the valve clearances on my 748, problem is the haynes manual, workshop manual and a ducati website i found all give different tolerences. If i go by haynes only 2 openers need adjusting but if i go by the workshop manual 14 need adjusting?
Advice please.
Neil
Neil,
I think it's reasonable to assume that the Ducati workshop manual is correct, after all they make the things.
The openers are quoted as;
Inlet 0.13 - 0.18mm, Limit = 0.05mm
Exh 0.18 - 0.23mm , Limit = 0.05mm
and closers
Inlet 0.13 - 0.18mm, Limit = 0.20mm
Exh 0.08 - 0.13mm , Limit = 0.20mm
As I interpret this, the first figures are what you should set them to. The limit is the min permitted clearance for openers and max for closers.
So in old money I'd be setting the openers to .006" inlet and .008" exh and the closers at .006" inlet and .004" exhaust.
But if the opener clearances are greater than 0.05mm (.002") then they are within the service limits and could be left alone (although I doubt if you'd want to let them get that tight.
The same for the closers if they are less than 0.20mm (.008")
You need to use a bit of commonsense when doing this, after all the shims come in .05mm (.002") increments and I think it is better to aim as close as you can to the specified tolerance, only resorting to grinding shims if absolutely necessary. The shims as they come from Ducati don't seem to be exact sizes either, perhaps there is a manufacturing tolerance involved.
I don't know if this helps Neil but feel free to discuss it further.
