MartinH
Stripped the Multi last week ready to do the valve clearances, a mate was supposed to be coming along to do the actual shimming etc if I got the tank/bodywork of etc to make easy access for him. Needless to say I am still waiting for him to arrive
Have measure the clearances 3 times now (and got exactly the same figures) basically all the openers have closed up (especially the exhaust valves) and the closers have opened up. So every one needs reshimming. Looks like I am gonna have to do the job myself.
What I need to know is has anyone got any tips for retaining the valve when doing the closing shims? I really do not want to have to remove the heads if a valve drops down. I have been told to either tape or zip tie the valve in postion but really dont fancy doing it this way.
Is it an option to remove exhaust/induction system to allow access through the ports to the underside of the valves and then be able to support them with a plastic coated screwdriver or similar?
All opinions gladly received.
