valve adjust help 748
zxmarc
I have a few track days comming up and want to use my 748 that i purchased a few days ago, problem is i need to know if the valve clearance is ok? or will the engine blow up, they are on the loose side so i'm guessing that is good compared to too tight,
here are the specs
Vertical .........................................
exh op .007 closing .004 and op .008 closing .004
intake op .005 closing .0045 and op .005 closing .0065
horizontal ...............................
exh op .005 closing .001 and op .006 closing .0055
intake op .0055 closing .0045 and .0055 closing .0045
thanks
The inlet openers should be set to .006" but are within acceptable limits between .002" to .007"
The exhaust openers set to .008" with limits of .002" to .009"
Inlet closers set to .006", limits from .006" to .010"
Exhaust closers set to .004", limits from .004 to .008"
Earlier specs gave closers at .002" all round with a maximum of .008"
One of your horizontal exh closers is a bit tight at .001" but as long as there is clearance it should be alright.
Generally, openers get tighter as the valve seats wear and closers get looser.
here are the specs
thanks
I'm just being nosey....how many miles on the clock?
i don't really know the milles on the engine, should be around 14000 km's. I bought the engine to replace one that dropped a valve. The seller said it was serviced not long ago. I checked the valve clearance before droping it in the bike.
