Drumnagorrach
If I leave my M900ie (2002) for a month or so without starting it,it oils the plugs a couple of times before it runs. I know there should be no oil in the cylinders,but I am surprised it's ignition system isn't up to burning the plugs clean.
To that end I have been thinking that there might be aftermarket coil's that would improve things, Any suggestions ?
In the year I have owned my Monster ,it has been a bit prone to plug fouling,when I first had it in at my local "Ducati expert" for the TPS to be set up,it fouled the plugs on tickover ( I later had to make up leads and set The TPS properly myself )so I guess at very least I need to change the plug leads.
Any known problems with Ducati's ignition systems ?
Lee
Lee
