Updated Timing Belt Tensioning Data
Gizmo
Forum Geek
Picked up from a technical bulletin post on Sport Classic, I don't know if it applies to all engines or just the 1000DS so its worth a check before setting belt tensions
Timing belt adjustments must be performed with the engine at room temperature. The DDS kit probe measures belt tension using frequency readings in Hertz.
All previous and new model Ducati’s requiring belt tensioning now will be standardized to the below specifications.
When checking and adjusting timing belt tension at the recommended scheduled maintenance intervals, if tension reading is less than 70 Hz (minimum allowed value on all Ducati motorcycles), reset belt tension as follows:
All models:
Belt tension spec for new belts upon replacement:
110 Hz +/- 5, Horizontal and Vertical
Belt tension adjustment settings for used belts when inspected value is determined to be 70 Hz or less:
90-100 Hz +/- 5, Horizontal and Vertical
Refer to the appropriate shop manuals for cam timing procedure and belt tension setup, then reset to the tensions for service.
