heres a tip for ...
dont put a rolex in one .....we`ve got a big one on the boat and a certain dive supervisor put his seadweller in it...oh it was lovely n shiney when it came out ...just a pity the bezel had almost dissapeared lol![]()
moral of the story is ....use soap n a nail brush...![]()
No bl@@dy use for a blocked pilot jet though!![]()
they work much better when they are heated, my mate turns his on at the start of the work day and doesn't use it until it's warmed through fully.
ahh thatll be those things in carbotooters...![]()
There are youngsters on here that haven't a clue what you are on about!![]()
As I understand it just using it warms cold water but there seems to be a suggestion that somewhere about 60C is more efficient for cleaning.
Again there is specific cleaning solutions available for say carbs although plain water will take a lot of muck out.
ProjectImola004;84803. said:Jets and other small fiddly bits didn't get dipped in it
Any particular reason why not?
Would have thought they would be likely parts to gum up.
Cellulose thinners is the best stuff to clean carbs and jets with. It dissolves any gum and petrol residue....oh I just clean them with clean petrol and an old tooth brush etc. - force of habit!!!![]()
Yes I was going to do that (apart from any rubber bits!) and wondered if you could use thinners in an ultrasonic cleaner or would the heat generated cause combustion of the fluid?
Some of the carbs have been standing for 10/20 years so the "air line" technique on it's own is not going to help.
Perhaps I just want to justify a new toy?![]()
Given the volatility of thinners I'd rather not find out.Yes I was going to do that (apart from any rubber bits!) and wondered if you could use thinners in an ultrasonic cleaner or would the heat generated cause combustion of the fluid?
Stewart, that watch repairer you mentioned to me might have one in his w/shop?
Dinnae ask...dinnae get![]()
Given the volatility of thinners I'd rather not find out.Talk about living dangerously
I have a loan of an ultrasonic cleaner for the gummed carb on the Aprilia RS I aquired recently and have been told to use plain old Turpintine to clean carb bodies, jets....the lot! :fart:
Turps in the cleaner?
IIRC dishwasher powders/fluids are strongly alkalineYip...Turps in to the cleaner.
Then.....but dont tell the wife....put the lot, except the jets in the dishwasher!!!!? Remember and have it empty of dishes or if she finds out she will not be a happy bunny!!
Great results...for a spotless carb!![]()
IIRC dishwasher powders/fluids are strongly alkalineNo wonder your carbs come out spotless
