Tyre Wear On Track
  • Thread starter Thread starter Mad Dash
  • Start date Start date
M
Mad Dash
Just visiting
OK guys, need some help here. On Jerez last year tyres weren't lasting well at all... day and a half, this was Pirelli Diablo Super Corsas. This year used Pirelli slicks and they were torn to bits, NOT worn, each day... that's a tyre a day.
Now, inbetween times went to Almeria (Diablo Super Corsa) and they lasted the full three days (albeit a VERY cold track).
So, the question is WHY are these tyres being ripped apart. The tyre is shredding on the RHS (Jerez mainly right handers). It has been suggested this is "cold tear"... but I don't know.
Any thoughts / comments ?? Bike's a 1098R
Probably because your suspension is not properly setup.
Excessive compression damping is usually the culprit for knacking tyres like this. Are you using warmers and are you keeping a careful watch on tyre pressures? What temperatures were you running?
Cold tear is only a problem if you aren't allowing 5 laps or so to warm the tyres and it should be less of a problem on warm days.
Thanks for that - warmers were used, and carefull eye on pressures all weekend. I agree that the finger of suspicion would point at suspension, just baffled how Almeria showed nothing but an evenly worn tyre after THREE days. Don't know about temp.
I agree about cold tear, tyres were warm and kept easy as well for the first lap or so, it just looks like cold tear, but the tyres and indeed the track were were certainly not cold. Amazing what you find on google !!!
Here's what you need to do:
Ducati suspension is always overdamped - especiallyrear compression.
Std settings for Ohlins is usually 14 out for compression and10 out for rebound. Set them at 16/17 and 12. It gives the tyre an easier time. The suspension should be doing the work - not the tyres. You need compliance for grip and life.
Set tyre pressures at 28-29 rear cold and 31 front cold.
Put the warmers on.
Measure pressure rise untilthey reach the correct temp' of 75-85 degrees C. Pressure should be about 34-35 at both ends.
Do a few laps. Measure tyre pressure & temp' - reset pressures accordingly.Check the tyres for damage/wear. If tear is reduced then keep on reducing compression until you detect abnormal behaviour in terms of handling or your personal comfort/confidence. When tyre damage/tear is no longer occurring then you're getting close to the right settings.
Don't make comparisons between the Diablos and slicks. The Diablos are not proper tyres - they're road tyres. They require completely different settings everywhere.
Re. tyre temps get an infrared thermometer - they're invaluable. Keep notes. Tyres are a bit of an art. By spending time on careful setup I went from one race and 12 laps a set to 2 races and practice out of a set - about 40 laps. It's worth the effort.
i forgot to say...you get different wear for different circuits and times of the year. I have different race setups for many circuits and different again when it's wet.
I even sometimes change springs for wet/dry days so, don't get too hung up on different tyre wear at different times. You're riding a 170bhp superbike, not a commuter.
great feedback, knew the forum would sort it out. Certainly looks like the 1098 suspension is the culprit, that in my mind should mean that Martin covers the tyres under warranty !!!! :rolleyes::lol2:
The answer!
I think you need Hegman Racing to look at it for you, they are specialists in the 1098 range as you know!
I'm sure I can put in a good work with Heggers for you if required.
G.
1098R ??? Is this too a 1098R ???? This one a 1098R too ?? Three ???
The rest, as they say... is history...
you 1098R is sh1t
