I didn't "recommend" anything, I just told you what I did and how I did it.Derek recommends a brush on paint and there is good looking POR15 engine paint in 'aluminium' but I don't trust myself to do a good job with a paintbrush.
It will look mankyStarting to wonder if the bare alloy heads are a good idea or if they (front!) will just look manky after a while![]()
It will look manky![]()
Not convinced what to do the crankcases with yet ....
The horse has bolted!Re; two pac. Ask for 'direct gloss' instead. You still need to use an air mask but personally I would say you need an air mask with any spray paint regardless of type.
Im doing my shortly with Acid #8 etch primer which will be followed by Rust-Oleum Stove & BBQ Silver heat restistant up to 650 degree's and a massive £7.89 from you local B&Q.
etch primer here and Hycote engine enamel...work in progress..literally
Any pics?
LOL - I didn't realise you were doing the WHOLE engine in a oner
Looking good - I definitely prefer that paint finish to mine. Want to swap?![]()
