Serious Black
On my latest oil change I found aluminium flakes in the oil so now it is in bits on the bench awaiting a new gallery plug. When I pulled it to bits I noticed it had an oil pressure relief valve on the pump AND one in the crank cases. Both are fully operative. The motor is a 99 SSie. I have heard that this was about the time Ducati crossed over to the pump with the valve fitted and that the valve in the crank cases was disabled by a spacer. Anybody think of a good reason for me not to disable the valve in the crank cases?
