trickle charger not charging
Big Slippy
Hi,
Has anyone had an Oxford Optimiser 900 and when connected to the bike the screen flashes and the warning symbol is lit. Disconnect it, and screen stops flashing and all looks OK.
Charger has been connected to the bike all winter, screen never flashed until recently and now not charging as batt at 6.3 volts.
Have checked all connections, fuse etc, but all seems fine.
I don't want to buy another charger if its something bike related.
has anyone experienced this?
thanks
Michael.:confused:
Thy reckon you shouldn't leave it attached permanently.
Don't know Oxford warning lights but as Paul says could be the battery is fried.
Have you another battery (bike/car/mate's?) you could try hooking onto to see what happens?
...Don't know Oxford warning lights but as Paul says could be the battery is fried...
If it wasn't before it will be now with only 6.3V in it. I never trust these battery tender things. Give it an overnight charge on a trickle charger once a month.
I have went through 2 of these!1st 1 started playing up saying any battery I tried to charge was faulty so sent back and got exchanged!Haven't used replacement much and screen just stopped working so gave up and binned it.Replaced with a optimate 4 which so far is excellent,hasn't got the lcd screen but is far better build and features,saved and charged a battery that the Oxford wouldn't!
Thanks for the replies.
I've removed and charged the battery today and it's now at 12.2 volts. Have re-fitted and see if it's holding a charge then try it at the weekend. Optimate display still flashes, with wee warning circle in red though!!
1 day charge on the battery, and 12.2 volts showing. It has sat for 7 days until today. Re-fitted to bike and it started fine after 5 months.
Must be a faulty Optimate.
as
I was about to post to see what trickle chargers everyone was using as i was about to purchase 7 off because i have sold my house and still house hunting and my bikes are in other peoples garages all over ayrshire and i am going between one or the other every so often starting the bikes to keep them going so thought it would be better to put a trickle charger on each bike
over the winter until i found this old post from Derek. So am i best to purchase one charger and and do as Derek says and go round them once a month but my question is still the same. Which is the best one to purchase?. Your thoughts please.
Jimmy
My solution is a solar powered trickle charger. Over the winter the odd sunny day keeps the battery topped up (reading is normally around the 13V level). The other main benefit is that you don't need a mains power supply (which I don't have). I stick my little panel on the roof of my garage, works a treat.
can you advise what charger you have , Ive been looking but not sure what to get..
