Tps reset
yaddd
Hi all
wondering if any 1 local out there has the software to reset tps on 2005 999.Needle starting to bounce and stalling now and again.Was thinking of buying software myself but all new to me and don't no what setup i'd need ,due to work some 1 local would be good,
ANY HELP APPRECIATED
THANKS!
i may be wrong here about the 999.
ive only adjusted my TPS on the 748..its a physical adjustment and not a ecu adjustment ...you have to locate the pins on ur loom that are connected to the TPS and get a multimeter on them..then start moving the TPS around till you get correct reading on the multi meter with the throttle bodies totally closed..
as i said this is for my 748 but may work for your 999
