rxs748
Just managed to get my old 851 back on the road after a very long time. It has passed the MOT and is running reasonably well but feels quite erratic when trundling along on a steady throttle at low speeds. I seem to recall it always did this to some extent but would like to sort it if possible. There are obviously quite a few possible causes and I intend to start by balancing the throttle bodies and trying some injector cleaner. I have read the guide from Brad on setting up the injection but have not been able to find anything about checking the operation of the TPS - could this be done by the same method as setting it - opening and closing the throttle and checking that a smooth reading is obtained on the multimeter or is replacing it the only real check?
