Torque settings??
Dave G
Well I finally got round to starting some mods to my bike, but am frustrated at the trivial things that are holding me up. I'm relatively cautious by nature and usually check through things a few times before starting them.
Something as simple as torque settings have held me up for a couple of days, an email to speedymoto got me a value of 14Nm's for the top yolk I'm fitting (seems awfully low to me, but that was from the source.),and as I'm definately pulling my forks up by nearly a centimetre I've had to undo the bottom yolk bolts too, now can I find a definative setting anywhere for these?:mad: , I have a workshop manual on this computer and its not even in that,haynes is a bit vague giving a couple of value 'ranges',also these seem way different to the top bolts settings.:confused:
Does anyone have a definative setting for the oe bottom yolk pinch bolts?
I've just snugged everything up for the moment,and am debating whether or not to run with the oe brakes or fit the goldlines I've had in the box for a couple of years(just noticed the brake switch is broken if anyone has a spare let me know....8mm pivot type).
A 999 bottom yoke is 14 Nm ( I assume bolt must be same size), you don't need a lot of clamping force to keep it pinched up, over tightening it runs a big risk it'll crack the yoke, the clamp isn't designed to be "pulled tight" the leg should be a nice snug fit and the clamp just nips up on it. We see a lot of cracked alloy lower legs on MTB forks where people over tighten the axle clamp bolt, its got a torque of about 5 NM and loads of people crank it up with the long side of the allen key :(
The bottom yoke pinch bolt torque for the ST2/4 and the 900ss is 20Nm. I think the ST yoke is the same as the Monster one.
Thanks guys, my new 'issue' is to get a torque wrench that'll go that low :rolleyes: as mine starts at 28Nm's:D
