Top end gasket set - 79120031A
Pict
Just a heads (pun intended) up, if you in amongst your SS this winter. Above part number includes all the wee o-rings, base gaskets, inspection cover gaskets, cam cover gaskets, valve stem seals, inlet manifold gaskets, even a wee copper washer for that oilway cross drilling that leaks on the vertical head... also other stuff that I haven't worked out what it's for yet, probably tacho drive? It's very cheap compared with the price of the disctrete parts so if you even need just the o-rings for example I would recommend you buy the kit. You will use the other bits sometime ;)
See that screw arrowed in the attached picture? Well it plugs a drilling for an oil gallery. They invariably leak oil, usually on the vertical cylinder but I've seen it on the horizontal too.
A new O-ring will sort that. Pity the frame cross piece gets in the way of getting the head off.
