Looking around at timing belt tensioning tools and at the Facom tools as this has been mentioned a few times looking at some older posts.
Problem there is the cheapest I can find it at present is about £85 delivered which is not bad for decent quality specialist stuff, (unless someone knows of a cheaper retailer? or is selling a good second hand one?)
However, I noticed this one here, Laser and looks similar but appears to work like a micrometer to read the tension in NM
Has anyone used one like this, is there a NM setting to achieve, don't recall seeing anything in the Haynes book.
Essentially here i'm thinking long term and worth getting a tool that will give me consistent results time after time without the guesswork of the 45 degree twist or the 5mm allen key thingummy.
Cheers,
Mike
As an aside is there anyone close-ish to Skye with a tool like the above they'd be willing to loan when I'm ready to change the belts so I could then match this with the other (cheaper alternative checks) so i can see if i'd be happy with their accuracy for future changes
Thanks,
Forgot the link to the laser one, ooops,
laser tension tool
Cheers,
Mike
Thanks,
laser tension tool
