Timing belt lay/drive rollers play?
oldskoolracer
Just found I have movement in my timing belt drive rollers, it`s not end float , when I pinch the horizontal timing belt to increase tension I can see the drive rollers move forwards , I checked it with a dial gauge I can almost get up to 0.02 mm if I really squeeze the belt tight.... it`s the shaft that's moving not slack rollers , is this a sign of a shot bearing?.....impending doom? ...... it`s a wee bit of a worry , so advice is called on yet again! ......
My bad ...... it`s between 0.15-0.20 mm depending on how tight you pinch the belt , though the belts do look to have been running fine on the pulleys , would this play be taken up as the engine warms up? , the tension on the horizontal belt is a little less than the vertical one ....
Ah that's more like it 0.15mm - 0.20mm is 6 - 8 thou which you will be able to see. I'd suggest taking the belts off and feeling how the rollers turn. Do they spin freely with no roughness? Is there any sideways rocking movement? The tensioner bearings need changing, on the 4V engines are easily replaced and not expensive. I've got 6003-2RS1/C3 listed as the bearings but I'm not sure that's the right number. Whatever it is make sure you get the ones with the C3 suffix for high speed applications.
It`s not the tensioner/idler rollers I`m seeing the movement in , it`s the double drive rollers for the belts , if I pinch the horizontal belt really tight , I can see the shaft move ...... which worries me! ......
Sorry I'd misunderstood, it's the timing layshaft bearing. I'd be worried about that too. Pict has a similar problem with his Superlight and is thinking of an engine strip to replace them.
You could check how well the shaft runs if you took off the flywheel and cam drive gear on the alternator side. With the belts off you could turn the shaft and feel for any roughness. I suspect they could go on long enough but better safe than sorry although as you'll know the crankcase halves have to come apart so it's big job.
I just had the belts off , I cant find any play in the lay shaft bearing with the belts off , I tried to lever it back and forth to see if I could find any , so it must just be with the belt tension I`m able to move it.
Aye I know it needs splitting to replace them , not a great thought! ........ :eek: .....
Still , thanks for your help Derek , it`s much appreciated , thanks :)
I changed the belts and can get it to move up to 0.12 mm by squeezing the horizontal belt with both hands , i dunno if other folk check for this at a belt service , but with the belts off , you wont feel it by hand ...... i can`t tell if it`s recent , as i`m sure the first time i changed them i only checked with the belts removed ......
Have you noticed a whining when driving (rather than sitting idling)? That's what made me check mine, and as you say, you notice the movement more with the belts on - squeezing one makes the other move.
Whoever gets round to fixing first should post a 'how to' thread ;)
Is this about pillions?
Well funny you mention that whine pict ..... yep I did notice a slight whine off it one of the last times I used it last year ( but that was only as I was slowing down to enter a 30mph limit) ..... and I have been thinking about that since I found the play
my belts have shown no sing of trying to wander off the idlers or toothed pulleys .... it`s in the back of my mind could it be the bearing in the left casing that's going .... hence you can notice it more only with the belts on .... but I dunno ..... how bad is the play on your drives ?
I called G Tec performance ..... apparently you can flex the shaft by squeezing the belts tightly (it`s normal ) ...... if there is no play with belts removed it should all be ok
The SL is (literally) 5 deep at the minute and I can't be arsed hauling it out, but the bearing is definitely fucked. I'll probably tart up an engine that I have in stock (:o) and do a swap so it might be a while til I get round to actually fixing it.
