tick over and gearing on 916
:welcome:
Please take the time to introduce yourself here
Answer to both questions will be "yes". Increasing the tickover can be done by simply adjusting a screw - someone will be along shortly with a better technical description.
The quickest, easiest and cheapest way to lowered your gearing as by replacing the standard 15 tooth front sprocket for a 14 tooth. If the chain and sprockets are due for replacement, I believe a better ratio can be achieved by fitting a larger rear sprocket - but this would require a longer chain.
HTH
I prefer to go up on the rear sprocket rather then go less on the front. But you need a new chain.
Also like an odd number on the front. That's just me though.
thanks guys
willpop 14 on front as a starter till chain requirs replacing. been on Gearing Commander to see what effects it will have.Been stalling it a bit recently trying to protect a slightly worn cluch, hence the changes. also helps when wacking down the box!
