throttle ghost
Kristian749
Hi all, first time out on my newly acquired 749s...cold, amazing but; manoevering bike at idle, full lock right and throttle opened/ revs increased....never noticed once moving but again on return, on full lock throttle opens, when turned clockwise. Is this a known problem? Over tight throttle cable? Any advice appreciated.
Check the routing of the Idle adjust cable. My 999 failed it's MOT for this. After messing with the throttle cable I identified that the advance cable was the culprit and was being pulled by the other wires nearby. Took the switch gear off the bar and rerouted the cable to solve problem.
Sorry, it was like chrisw said, the prob was the route the throttle cable took, just moved it around till it wasnt moving when i was moving the bars from lock to lock
Hi Chris, when you removed the switch gear, does it come off and replace easily or is it a tricky electrics job?
You are not interferring with any electrics, just splitting the switchgear to get the idle advance lever out. you can then thread the cable where you want it so it doesn't foul the wiring. It's fiddly getting it back together, just remember the locating pin has to line up with the hole in the clip on othertwise you will not get it back together.
