I remember now that the black rubber ring was a bugger. It's mean't to sit under the flange of the filler cap taking up the space between it and the tank but it tends to slip down on to the part with the O-ring and get in the way when you are fitting the filler.
I'd suggest cleaning all grease off the filler assembly, the O-ring and especially the black rubber ring. Grease the opening neck of the tank then insert the filler carefully making sure that the black rubber ring stays in place while you do so. if you are successful in getting it mated keep the filler pushed down until you have got at least 3 equally spaced grubscrews tightened or it will pop back out again and there will be grease on the rubber ring making it difficult to put back unless you clean it all off again.
Sounds a bit pervy this
