Tank pad knob on SS
TonyV
Anyone know if I can just cut the knob off the tank which holds the rubber knacker pad on. I know its alloy but not sure how its attached.:confused: Ta
It's glued on and there is a knob in the middle that locates it. You might be able to work a length of nylon fishing line down the back to separate it from the tank.
Cheers Derek, but its the knob I want off, I'm putting a flat carbon pad on the tank rather than the original rubbery one, Ive had a new seat made and the colour of the uphosltery is darker than the pad.
Oops! I should read posts properly before replying :o Hacksaw ?
Yes you can. I've done it twice, cut carefully or grind off. the tank is complete and whole behind it.
Paint over the bare metal as a wee bit of protection before putting the carbon protector on.
