tank dent repairs central scotland
CJK
I know a few of you have recommended Guys/Co.'s for paintwork but what about tank dents ? The paintwork is good at the dents I'm hoping for a paintfree repair.
Any recommendations around Livi/central area.
To the left of the D,me being me,I'm tempted to have a go myself ;)
I took this tank as the paint is better than my original tank and like i said i'm hoping for a paint free repair.
no chance, the convoluted shape of the tank makes it incredably difficult to push the dents out, its a filler and respray job
I'd agree with Scotty. As I recall, the inner and outer walls of the Monster Tank are very close together down the sides I think it would be very difficult to get any sort of tool down there.
As an alternative it might be possible to cut open the inner wall of the tank, push out the dents and weld it back together again without damaging the visible paintwork.
Agreed. Going by the photos it looks like there are some angles within the dents. If you can take it with you on Sunday I can see it better there.
I already have a waiting list of paint jobs (including two S4 tanks) to do but have had to put back the startup of the business due to family needs. I may be able to recommend someone who can help if you are in a hurry.
Also, consider having the lower tank mount area brazed before paint, as it seems they begin to leak there after a while.
I didn't know monster tanks were double skinned. I do now.
They're not double skinned Lindsay, it's just that the upper side of the tank and the floor of the tank are both vertical at the sides with a very tight space between them. It's so that it clears the airbox and gubbins underneath the tank.
It's tighter to the rear but I can get a hand in and feel the dents no bother.
Ah yes - I can picture it. Thanks.
Thought your weren't a Vale fan? :lol2:
Ach you are aw very funny :rolleyes:
Gtf though :p now i have two tanks that are u.s. :mad:
Plus I've been and had two teeth hauled oot earlier,feeling a bit 2nd hand...feckin' sick of bikes to .. Pahhh
thinking about it this is quite important
the dents in the tank are from the handlebars bouncing off the tank when the bike has been dropped, which could well have damaged the hinge area its well worth brazing the hinge area before a repaint
I've even just used solder to good effect in the past
Well take it to a dent place and see what they make of it.
Hope your gums are feeling better soon.
Sorry you are a bit down in the mouth.
(From the DB joke book! :()
Spoke to a pal who does dent removal in the Central Belt and he says he doesn't reckon anyone can do this without painting etc.
Says he knows someone who does repairs but involves putting a hole in the tank to pull it out and would need repaired afterwards.
Says bike tanks are too thick just to "pop out".
Aye Scotty,that thought crossed my mind yesterday,they are both sound looking.
sorry to dissapoint but no way either of these tanks will repair without repainting have tried in past with shallower dents than these
as mentioned elswhere tank walls are not like car panels that will sometimes just pop back if you did try pushing it back from inside no doubt you would end up with ripples outwards
