sam
After reading a post where someones tank had been damaged I decided this morning to give a go at taking out a dent that was in a tank on yet another project I picked up recently. I did not want to use filler as there is a chrome panel which will be exposed when I do finally paint the tank again.
I tried using a tire leaver at first but managed to bend that so used a piece of 16mm round bar placed it in a vice and gave it a scud with a large hammer to bend 2" at the end.I then buffed a radius on the end using a fiber disc, fastening the bar to something solid I placed the end through the petrol cap and started to slowly press around the indentation forcing it out.
After getting close the shape it should be I then fed the tank back and forth across the bar on the dented area. I found by placing your thumb over the dent you could feel where the bar end was, it did leave a couple of small dimples outward but this was due to not polishing the end of the bar well enough.
I will tack weld a piece of shaped metal to the curve of the tank to the bar end and when inplace on the underside I will use a small planishing hammer to take these out. There are a couple of deep scratches but a wee bit of filler will take care of that.
