swinging arm bearing removal
st2boy
Hi everybody seen a few threads on web asking how to remove the swinging arm bearings from the crankcases on ducs.
Heres how i do it.
after swing arm and all other stuff thats in your way to do the job is removed.
1. pick out the outer seal with a hook ended scriber.
2. use a heat gun to heat crankcase area around bearing {20 mins}
3. use an internal bearing puller and slide hammer to pull out the inner race of bearings {one at a time, outer then inner}
4. then get a suitable drift { an old swinging arm pivot pin is ideal}and use it
to punch the circlip and inner seal in to the crankcase well.
5. apply some more heat.
6. get a socket that has the same diameter as bearing outer race and extension bar
and drift the bearing shells in to the crankcase well.
7. take your old pivot pin and mash the bearing shells in the crankcase well.
8. use a set of long nose pliers and magnetic pen to remove the debris.
and thats the hard work done .
I will assume, that if you are tackling this, you wont need me to explain how to insert new bearings
Okay its a bit brutal but it works and only needs done once in bikes life if you clean and grease them regular.
Good luck happy spannering st2boy
Thanks ST2boy, for insight, though I am still realing over the Mash the bearings up while still in cases to enable removal from said cases. Ouch is this the best way I have never done this but would using a fine wheel in a dremel or similar not help or am I talking crap.
Paul
RWG
Hi Paul
Yes it sounds really severe ,but they break up easy enough ,that is why i use the inner bearing puller
to remove the inner cage and rollers .
I have actually done this twice ,once on my 900ss{and it covered a further 20,000 miles and is still going strong
as far as i know, K71 ELS} and yesterday on st2 yesterday .
i actually only had to mash up the counter shaft side ,then used the socket and extension bar to drift
the otherside out.
I wont mention any names but ,this is the way a certain ducati mechanic does it every time.
cheers ALLAN
Hi again Paul
yes i would think a dremel ,mains powered of course will work.
be prepared for sparks everywhere and keep a steady hand.
good luck Allan
Did mine just last week, used a Dremel with a grinding stone on it as I couldn't get a cutting disc in, went through a few and it makes a mess but works. Getting them in is tricky too, gonna use a threaded bar w/nuts and a socket on one side (big enough to press on the casing) with the bar running through to the other with another socket on the outer edge of the bearing. Tighten nuts on the bar and it will pull the bearing in.
Hope this makes sense?
Yeah thats the way i install them ian.
i didnt bother with the circlip or inner seal as i can't see them moving or any way for road grime to get in.
i did this today,
found that a bit of blowtorch heat (no need to burn the paint off) and a blind bearing puller worked a treat
no real need to knock seven bells out of the rollers etc
