Swingarm / Huggar mounting boss seized - advice please
iconic944ss
Bit disappointed about this, wanted to change the ugly looking rusted bolts on the huggar and got all of them done except next to the rear sprocket, turns out the boss is seized onto the bolt and now the whole thing just spins in the swingarm.
Attempting to use some releasing oil but I'm dubious of it working given the state of the bolt, options please or has anyone had this problem before?
Cheers - Frank
It seems to be quite a common problem Frank, especially if the screws haven't been treated with an anti-seize grease. Drilling it out is about your only chance but that doesn't deal with the rotating clinch nut. It will be hard to run a tap through it if it keeps turning.
Cheers Derek, I thought that might be the case.
I wondered if trying to superglue (v. carefully) the boss in place might work???
I'll think that one over!
Had the same problem.Drill the captive/rivnut out.Then fit rubber fairing/screen wellnuts.Not original but works a treat.
