Streetfighter Clutch Problem
Argyll9193
Hi Guys
Recently I bought my 1098s street fighter and its starting to make weird noises from the clutch. When I move off there's no problems and doesn't slip however when I'm in the town and dip the clutch for slow speed movement it makes a noise that I can only explain sounds like a butcher sharping a knife with a bit of rasping.
It just doesn't sound right, The bike is a 2010 model and has only 2000 miles on the clock. I checked the previous owners docs and the only thing that I can find related to the clutch is a custom pressure plate fitted.
If anyone has come across this before can you advise me what they think the problem is or is just the way that it is.
Cheers Dougy
The dry clutches often have a habit of making a graunching sound on take off as you release the clutch, usually fixed by cleaning the plates but that doesn't sound like your problem. It could be the release bearing in the pressure plate but at that kind of mileage I wouldn't have though so, but it's only a 10 minute to take the pressure plate off to check it so worth a look.
1198 does the same thing, does it when doing in town driving and stopped at lights
pull away in first and sounds like the brakes are sticking but ok in other gears
got the clutch plates cleaned up and put and open vented clutch cover on and seemed to help
mine had 2800 miles on it
not sure if that will resolve yours but helped mine
Had the same problem with my 748.Only solution is to strip regular and clean out the dust.Some times the outer drum wears and also causes it to grab.
Thanks gents for all the advice, I,m going to put it in and get it checked oot. I had another wee think about it last night how to explain the noise when moving off at a slow speed, it sounds like using a air drill when the nut is at its tightest definite rasping sound but all ok when going through the gears. My old 748,s clutch used to rattle like mad but never had this problem. I,ll get it looked at and get back to you all on the result of the findings.
