Stator Removal
Pict
Haynes book of optimism;
"Unscrew the two bolts securing the stator, then remove the assembly from the cover.."
Aye! Right!
Am away to bake the casing in the bearing oven for a wee while. Otherwise does anyone have any suggestions on how to get the bugger out intact?
As you were...
With the casing hot enough to not be able to touch it (welding gloves!) I got wire down where each bolt was and looped up to make a pair of handles and twisted them together to make one handle then belted round the casing with the rubber mallet while taking the weight/shock on the 'handle'. Once it eventually started moving it came out not too bad. Not easy though.
I had to replace the stator output wires on my on's 916 recently. To remove the the stator I warmed up the casing with a hot air gun then turned it over and banged it sharply down on the wooden bench top. The stator just fell out. :)
