Starting woes
ian900ss
Ok, after my off earlier in the year the bike has been of the road. Went to start it the other day and I have a recurring intermittent starting issue which seems to have got worse.
It has happened before but usually disappears. It goes like this
Key in, idiot lights come on, hear fuel pump, press in starter, hear a click (solenoid) and perhaps a tiny movement from starter perhaps not.
I have a new battery bought early this year. It's charging on the Oxford charger and showing good strength. I have tested the solenoid off a battery and getting a good solid clunk, I have tested the starter out of the bike and it's spinning away. When I go to start it I am not getting a loud click fron the solenoid, almost as if I am losing power somewhere. It sounds a lot better when I just use a battery straight to it.
Its not going away now, it's just not starting at all.
Any ideas??
Ian
Could be an earth issue
try clamping a jump lead between the earth on the battery and the engine see if it makes any difference
if it does clean and tighten all your earths
The bike always started great when I had it :D
Seriously though Ian. Start by checking ALL the connections. Battery terminals, battery earth, solenoid terminals and starter connection. When you press the starter button the solenoid should engage, usually with a fair clunk that you should hear, and as soon as it does the starter starts turning.
Is the solenoid operating? If it is it may not be connecting internally. You can check this by bridging the solenoid terminals with a screwdriver. Beware because there will be big sparks but the starter should turn.
If it not operating: When you press the starter button, the solenoid is energised by the ECU providing a ground to the trigger coil the other side of which should be at 12V. These wires are to the in-line connector a few inches from the solenoid itself. There is a red/white wire with 12V from fuse 5, this also supplies the immobiliser and the ECU. Check that fuse is in good condition with no oxidation on the blades.
The other wire is red/black and goes direct to the ECU body connector (grey) pin 1.
The ECU requires that the bike is in neutral and/or the clutch is pulled in before it will earth the solenoid to allow a start. The stand switch shouldn't prevent it starting unless it's also in gear. A faulty clutch switch AND a faulty neutral switch would prevent the starter working. The neutral light should be on, if not, pulling in the clutch should allow a start provided the clutch switch is working ok.
I hope I've not made that sound too complicated.
Thankyou all for your help. I will check things this week. It certainly looks to me like a bad connection as it has been intermittent in the past.
Thanks, I'll report back
Well, thought I would let you all know how I go on...Took a while, looked at solenoid connections etc. Bike started with TWO batteries in parallel so I then became suspicious of the battery. Ordered a new one and today when I took the other one off there's a hole in the back of the battery where the screw head for the lower tray bolt goes! So basically when I came off it, it had punctured the new battery. I thought to look elsewhere as I had just replaced it, earlier this year. Just glad it's fixed and running now. Thanks for advice.
Ian
Good to hear it's running again Ian. Funny about the battery. When I came off a few years back the battery got punctured with one of screws holding the fairing halves together. I replaced it but plugged the hole with Isopan and it lasted for another couple of years on my son's 1098.
