It's probably easiest to try another pair of plugs first. They could be fouled. They can seem fine when you check the spark with them out of the head but under compression the spark tracks up the side of the insulator instead of jumping the gap.
If that doesn't do it then it may be blocked starter or pilot jets if the bike hasn't been run for a while. Unleaded left in the float bowls will evaporate leaving a gum that can block the jets. If I'm laying a carbed bike up over winter I turn off the fuel at the tank and run the engine until the float bowls empty that makes sure nothing will get gummed up.
