starting problems clutch + sidestand
Kristian749
Hi all, my 749 has an intermittent issue with starting; when out and about I'm having to start it with the clutch in and sidestand up (in neutral). It got a bit wet on a run about 4 week's ago but it doesn't normally see rain and I always wash it carefully. Fitted a new battery and sprayed connectors on stand and clutch with wd40. If it stands for a few days in the garage it will start fine sometimes but generally it's sit on, clutch in then it starts fine.
Anyone help me? I'm looking to sell but won't until it's sorted.
Kris
It sounds like the ECU thinks the bike is in gear. If it is not in neutral it will only start with the clutch held in and if the stand is down it won't start at all. You should check the operation of the neutral switch.
