starting problem
Scotty
booked mot, and yup you guesed it bike wont start
remembered to turn petrol tap on (eventually)
have checked for a spark on rear cylinder with a new plug (seems i dont have a plug socket to remove these plugs :( )
it ran the other week
i can only assume ive disturbed something putting faring back on
any ideas ?
unfortunatly nothing so simple
if i had any sort of electrical problem that would stop a spark to the plugs right ?
and whislt in asking about spark plugs what on earth does the 10mm or 14mm etc sparkplug socket actually refer to ?
10mm is the plug diameter, as is 14mm - which isnt the hex size that can vary with diameter too -heres an explanation
BCPR6E-11
B = Thread Diameter = 14mm
C = Construction = Hexagon size = 16mm
P = Construction = Projected insulator type
R = Construction = Resistor type
6 = heat rating (2 = hot - 11 = cold)
E = Thread reach = 19mm
11 = Gap width (8 = 0.8mm - 20 = 2.0mm) = 1.1
Scotty,
Is the bike in question the Monster or the SS? I presumed the SS.
If it's got sparks and compression and the starter turns it over it can only be a fuel problem.
umm plug probelm it is/was
new plugs and now with a flat battery it at least tryed to start
think i might have flooded it beyond belief it stank of petro lwhen i took the plugs out and it was 3 hours ago i tryed it last :o
however plug analysis is there something wrong ?
http://www.drscott.plus.com/plug2.jpg
What a horrible looking pair of plugs :eek:
They're both a bit oily and sooty. I'd say the last time they were run was with a rich mixture. Did you let the bike idle for a while with the choke on last time? Also the needle jets on the carb models wear, richening the mixture at smaller throttle openings causing poor low speed running and flat spots.
By the deposits on the plug electrodes the front cylinder is burning oil - probably not much to worry about. The rear one on my SS used to look like that after a season, not black though.
I'd fit a new set if I were you
yhey i have an MOT
doh doesnt seem to rev very high/quick tails off over 5 -6 k rpm (havent had it past that) and a smoking sort of thing going on around the rear cylinder ~:?
If its an old bike the 'finance owing' is probably down to the finance company not removing the details from the database. I had the same problem when I bought the 94 monster, it was showing being on finance even tho it was too old to buy on finance!
yhey i have an MOT
Best thing to do is take it for a gentle run. Empty the float chanbers first, put some nive new fuel in and one started trickle a little redex straight through the carb belmouth - this is going to make it smoke like hell for a few seconds. Then a gengle run for a good half hour to make sure everything is warm.
Then stop it, have a look for oil leaks round the cylinders, check the plugs again.
From your picture the plugs just look a little ritch, the front one running hotter than the rear, as you'd expect. Often a little use sorts these things out.
Hope this helps
:doh:
these ducatis run a lot better on two cylinders dont they :rolleyes: actually pulls like a train rather than limping, must remember to put HT leads back on properly
but to go with a Yhey theres always a DOH getting clutch slip now like
:o
